Originally posted by The Dude
View Post
Power Transformer confusion Fender Prosonic
If the Mercury drawing is correct, both 0V wires (Yellow/Black+Green/Black) and both 120V wires (Black+Red/Black or Violet) should be tied together.
One must only parallel same (and in-phase) voltages.
Reversing the leads of one winding results in a short.Last edited by Helmholtz; 12-21-2021, 11:03 PM.- Own Opinions Only -
- Likes 1
Originally posted by Greg Robinson View PostSorry, seems my instructions have caused more confusion than been of much help. Hopefully this drawing will clear things up. And The Dude is quite right, measuring from Red-to-Red will get you about 728VAC under load, likely higher unloaded.
If we "flip" the bottom half of the dual primaries, white and white/blk are still floating, but we'd swap BLACK/YELLOW with BLACK and all becomes hunky dory wired as below!:
BLK HOT ---> Thermistor ----> Violet ---(internally connected to...BK/RED)
BLACK RED/BLACK (BLK?RED TERMINAL)
YEL/BLK + GRN/BK +Neutral
Perhaps my explanation is wrong, but this wiring is confirmed as correct, putting out good voltages on tubes with a rectifier installed.
Originally posted by Mr_bibbles View Post
Greg, even if it was confusing I appreciate every answer I get on here! I think that your drawing may still be incorrect, although I think I mat have solved the mystery... is the second half of the primary inverted on the MM schematic from what we expect from the Prosonic? AS in, we are all reading it upside down?
If we "flip" the bottom dual primaries, white and white/blk are still floating, but we'd swap BLACK/YELLOW with BLACK and all becomes hunky dory wired as below!:
- Likes 1
Yep, turns out Mercury have changed the phase arrangement of the primary windings but kept the same colour code, I suppose just to be deliberate dicks? I can't think of any other reason to do that, and it's just cruel.
TYVM all involved especially Greg because without your guide I wouldn't understand what I was TRYING to do. Cheers!
They still had it labelled as 120V and 0V terminals as far as the phasing goes.
That was the way I thought it was going from post #1 & #2. I guess I missed that it was not being done that way.
Glad you got it sorted out.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
