Vox AC30CC2 strange behavior
  • Vox AC30CC2 strange behavior
    Good evening everyone, I state that I am a rookie in the field and I would like to ask your opinion on a strange behavior of my Vox AC30CC2.
    I replaced the filter capacitors today and after reassembling everything and turning on the amplifier the output signal was very very low.
    At one point I gave a particularly strong strum on the strings, and the signal became perfect.
    What could have caused this behavior?
    Thank you very much for any replies.
    Cristian
    Check any Effects loop by inserting a cable from Send to Receive.
      A bad connection somewhere. Check the wire dressing and make sure everything is looking good as it was.
      There are a whole host of interconnectors on these newer Korg amplifiers. Make sure they are OK.
        Thank you!
          Chopsticking the amp while playing through it may reveal where the fault lies. I use a melamine chopstick with a sharpened point, but any non-conductive material that's long enough to maintain a safe distance should be fine. Sometimes gentle pressure on a component, connector, wiring or circuit board is all that's needed.
            I just remembered that in the past (so before replacing the capacitors) the amp had had the same behavior. Then as now it had been shut down for about two years. I don't know if this could be part of the cause. Anyway, after that hard pick, the amp worked perfectly.
              Do check/clean the insert/effx jacks as loudthud pointed out in post #2. They are often the cause of this symptom.
                Also inspect the loop bypass slide switch.
                  Hey, thanks again for your replies.
                  I did some test on your advice and here is the results:
                  - Nothing happens if I insert a cable on send/return
                  - Sound disappear if I touch the loop bypass switch (even after the amp works correctly)
                  Btw the amp stays at very low volume for a couple of minutes and then goes to normal working state.
                  It is as if something inhibited the start of the power section and then suddenly disappeared.
                    So clean that switch.
