Another oldie I picked up. It has 120 Hz hum and I want to replace the filter caps.
Schematic would really help but I have not found one yet.
Having a challenge with the filter caps wiring, values, pin locations, etc...
Tube line up is
6SC7
6J5GT
6V6GT
80
The large 40 uF 450V orange Sprage is loose and not connected. I cannot determine where it was connected but I suspect it went to one of the pins on the plug going to the speaker which is where the OT is located.
Wondering where this one is supposed to go? Also wonder if this one was thrown into the mix and not part of the original layout.
The multi cap has the following values and where I suspect they go. I cannot judge most of the colors because of 70 years of aging and I am a bit color blind.
red/white 15 uF 350V - either going to pin 1 of 6J5GT or to OT
red 15 uF 350V - either going to pin 1 of 6J5GT or to OT
blue 10 uF 25V - maybe pin 8 of 6V6GT. Is this a bias cap?
black common to ground
yellow 10 uF 25V - pin 8 (cathode) of 6J5GT. Is this a bias cap?
brown negative - what is this? - maybe pin 8 of 6V6GT
There is a wire that looks "white" coming out of this cap that is taped off. Cannot really see a blue wire on this cap, or I cannot tell the diff between blue and brown.
6J5GT pin 1 is listed as the "sleeve". I assume no internal connection to the tube?
Thank you for any help or schematic! MC
Tube line up is
6SC7
6J5GT
6V6GT
80
