One of my clients sent over a Roland KC-880 Keyboard Combo amp, with no output. I have everything coming thru fine on the headphone output, so as far as getting that far, all is working. I pulled it apart, which requires removing everything....control panel assy, speaker grille, both 12" speakers to find the power xfmr mounted by itself, along with the power amp assembly. It uses three TDA8920BJ Class D amps (heat-sink mounted power amp IC's). Loads of Radial mounted Time Delay fuses, all intact, and on the bottom side of the board, receiving the control signals from the control panel there's a number of SMD xstrs and diodes. I found Q4, SM code LA, which read out as a BF550 PNP SOT23 part, which had failed. Closest I had to that was a BC856, also a SOT23 part. slightly higher voltage/current (-80V/100mA) vs the -40V/25mA part. Installed that, it being the only part I found defective on that assembly.
With it plugged in prior to disassembly, I was only seeing 30W power consumption @ 120V, where the spec sheet calls out 98W...no idea if that's true, first time I've seen one of these.
Put it back together, crossed my fingers and powered up. Still only drawing 30W, and again, no output from the speakers. Everything on the control panel is SMD land. I did just notice the Master Volume pot took a hit, with the control shaft knocked out of axis by 10 deg or maybe 15 deg. I had previously checked the four gang pot for continuity, and all four decks read nominal, as did rotating the knob yield variation in DCR.
I don't have the service manual for this...just the block diagram from the owner's manual.
Anyone have service doc's on this?
KC-880_OM.pdf
Thanks
KC-880_OM.pdf
Thanks
