One of our Aguilar DB 751 Bass amps arrived from our rental inventory with the note 'Won't Turn On'. Pulled the cover....and oh, yeah....I'd agree with that statement.
The T16A Mains fuse blew, of course. The outputs are Exicon 20N20 & 20P20 Lateral MosFET's, in TO-3 cans, socketed. I know I can turn regular Power MosFET's on and off with my Fluke 8060A DMM in Semiconductor Test mode, which has over 8VDC behind it's 1mA current source. I can't get these to turn on or off, whether plugged into the PCB or removed.
I was likewise somewhat unnerved by seeing the outside wrappings of their Toroidal Power Xfmr burned away from the heat of the nearest radial Power supply cap mounted on the PCB. While it wasn't physically touching the xfmr, there was enough heat to melt the wrappings. After removing the power amp module, and checking the bridge rectifier (which is a common failure in these amps), which checked out ok, I replaced the mains fuse and plugged it in, ran up the variac watching for any arcing on the xfmr as well as sudden current surge to be shown on the power analyzer. All came up nominal, so other than the burn area on the power xfmr, looks like the chassis survived.
Aguilar owns the rental gear of theirs in our rental depot, so I'll contact them with my findings, and see if they just want to replace the amp module (having trace failure on Q106 & supporting parts), or put it all back together and return the entire amp.
Is there some trick to doing basic go-no go testing on Lateral MosFET's?
Exicon ECF20N20 Lateral N-Ch Mosfet.pdf
Exicon ECF20P20 Lateral P-Ch Mosfet.pdf
