Green board BJr. Reverb hums. Checked connections, re-terminated cables at board as one shield was iffy. No change. Hum apparently coming from output of tank, and changes as I move that end of the tank farther from the speaker. Goes down appreciably if I push the tank to the front of the cab bottom. It has a MOD 8EB2C1B tank. It came in with a loose 1/4" input jack connection issue, and I only noticed this hum after I put it back together.
Is this a thing with these? Should I just push the tank away from the speaker? I don't want to re-engineer it since it didn't come in with this complaint.
