I have a homebuilt amp in which I copied the 5F6A circuit mostly. Originally I had in it a cheapo single output tap output transformer with a measured input impedance of about 3176 ohms. This is being driven by 5881 valves. I also had added a switch to wire the 5881's in tetrode configuration--as well as a switch to eliminate the negative feedback resistor. It all worked fine for years, but now I decided to upgrade the output transformer to a better multi-tapped Hammond with an input impedance of 4000 ohms. After installing the new transformer, the amp works fine in tetrode mode, with both no NFB and with a 39K NFB resistor--but when I switch it to pentode mode (standard 5F6A circuit) it works with no NFB but when I switch the NFB resistor in it oscillates with a horrendous low frequency.
I tried lowering the value of NFB resistor to 10K and no difference.
Any ideas?
Any ideas?
