Has anyone ever come across something like this? A Peavey 5150 II produces a tea-kettle noise on only the 4 ohm setting. I have it hooked into an attenuator, and have never experienced anything like this with the same setup before, and have also confirmed it happens on any speaker cab. Other than the low-medium whistle, the amplifier is working fine, and on the other two settings (8,16) are noticeably absent of oscillation.
Has anyone ever experienced something like this? Again, besides the whistling noise, everything seems to be functioning fine, and the only variable that changes it is the ohmage selector.
I have thoroughly cleaned and metered out the ohm switch, it seems fine from all apparent tests.
So far the Output transformer has passed all the basic meter tests, but I will be performing advanced voltage tests on it to see what I can find.
Thanks!
https://www.thetubestore.com/lib/the...-Schematic.pdf
Thanks!
