I have an 4 tube Oahu. Tube line up is 6N7G, 6C5G, 6N6, 80. This is a one knob (volume) amp with two inputs.
I have a 60 cycle hum that is only present when the 6N7G tube is inserted. Hum gets louder as the volume pot is turned up.
I clipped in a new filter cap that supplies that tube but no change. I do not have another 6N7G to try, I will be ordering one today.
Tube tested good on my tube tester, but that does not mean it will sound good. Can a tube cause the 60 cycle hum or is there anything else I can look for?
Both plate voltages on the tube are 253 VDC. Cathode is -0.04 VDC. Heaters are 6.5 VAC.
Closest schematic I could find is attached. It shows a different rectifier tube but the rest looks the same. Oddly input #2 bypasses the volume pot, not sure why.
Thank you. MC
Thank you. MC
