Output capture with PI in and off
Peavey Alphabass round two-troubleshooting
All board and chassis contacts in power section was reflowed and cleaned. The hum is still there, Swapping couple of novals was same. Think the noise is part of circuit supplied at such high voltages. The tubes are very high supplied 450v for buffer,425 for PI and 400 for fx recovery. The heaters are well supplied at 6.5-6,6v aso. May be possible to get a bit of noise in this circuit , is minimal, but still annoying."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Originally posted by catalin gramada View PostOutput capture with PI in and off
High frequency over 1 khz components was filtered by scope to get a clearly image about modulationLast edited by catalin gramada; 01-25-2022, 04:02 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
I don't know what is all this junk. Looks like a summation of signals with a periodically timing..May some enlighten me please ?
Doesn't look like PS ripple.- Own Opinions Only -
Hum with PI tube in is mainly 50Hz fundamental with some harmonics. Pulling the PI removes the 50Hz content.
Doesn't look like PS ripple."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Originally posted by Helmholtz View PostI dunno.
Maybe try a humdinger with elevated wiper.Last edited by catalin gramada; 01-25-2022, 05:08 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Does the hum stop when you ground C27 at J62?
If yes, the power amp is fine.
You might try to find hum sensitive circuit point by approaching (without touching!) components or wires with your finger (other hand in pocket!).
Maybe wear an insulating glove for safety.Last edited by Helmholtz; 01-25-2022, 05:34 PM.- Own Opinions Only -
Originally posted by Helmholtz View PostDoes the hum stop when you ground C27 at J62?
You might try to find hum sensitive circuit point by approaching (without touching!) components or wires with your finger (other hand in pocket!)."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
So I have this scenarios: v2b input shorted- hum, v2 pulled off -hum, PI input shorted-no hum.Last edited by catalin gramada; 01-26-2022, 12:58 AM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
We were discussing this area of circuit 20 posts ago. Did you break the circuit at the 5-pin connector? That is where the signal goes off board to the FX loop jacks and back.Education is what you're left with after you have forgotten what you have learned.
Yes I did. Due to the fact those conector carries also the nfb and local grounds to chassis I broked the circuit to the other end of the cable who connect the DI board ,Then with couple of "U" shape jumpers wire I tried all combinations out of DI board (eg. local ground conected and not conected to chassis with pre conected and not connected to PI) etc. I.ll do a drawing..."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
What if you simply use a piece of wire and ground the signal path at that connector? The ground pin is right next to the sigma pins in the connector.Education is what you're left with after you have forgotten what you have learned.
