Greetings. So I’ve read pages and pages of avt issues but none seem to match mine. I had a pop then the front leds went out. I replaced the 2 2.2ohm resistors and yay fans and lights back on BUT. I got an awful hum through my speakers. With it without a guitar plugged in and no matter where my vol settings are this hum is the same very loud. Upon investigation I have 45/50v at loudspeaker left Jack. Headphones and emulated line out next to headphones. The hum is present through the headphones socket and the fx lines make no difference, I’ve put a brand new jj tube in too. I’m completely lost, why do I have this voltage on the outputs I can’t see any visible issues with the pcb or components. Any help would be fab guys. Ta
Another Marshall avt thread
Most likely lost your output transistors. schematic attached
nosajAttached Filessoldering stuff that's broken, breaking stuff that works, Yeah!
Most bad parts don't look any different. DC on the output is a very common failure mode of solid state amps, particularly the one-chip type.
When an amp goes to DC, the result will almost always be a loud hum. TURN IT OFF, that "loud hum" will destroy your speaker.
Most likely a bad TDA7293Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostMost bad parts don't look any different. DC on the output is a very common failure mode of solid state amps, particularly the one-chip type.
45VDC across an 8 Ohm speaker will heat the voice coil(s) by around 250W without a chance of convection cooling as with AC.
The audible hum is just increased ripple caused by the excessive DC current the power supply is delivering to the speaker.Last edited by Helmholtz; 01-28-2022, 12:08 AM.- Own Opinions Only -
