Hello all
This came to me and i was told that it didn't work,
Anyway on tested it powered up and i heard hiss from the speaker. found it working but scratchy pots
Cleaned pot and tested all good until i turned up above 1/4 way then it go just sound like the output stages were blown ( Loud hum dc going to spk)
I quickly turned off and then when you turned on again it was ok working at low volume until you pushed it again
There is signs of a repair. Should have 2 x BUZ901 and 2 x BUZ906
I have BUZ900/901/905/906.
R2 ( 4.7R) was burnt out and has been replaced now . I would normally just order and replace all output stages and drivers, But they are no longer available and if they are expensive, so i would fit equivalents But i'm not 100% sure in this case will fix it
any thoughts on this before i replace the mosfets
Many thanks
Mr A
Trace Elliot GP7 150-300watt SM.pdf
Many thanks
Mr A
