Im working on a Max 112 combo (2012) , ive got it working now (cracked solder joints) .
I just want to make sure what I found is correct. One of the transistors had virtually no lettering left on it , as if it got real hot . Its U6 on page 3 .
So there is U6 / U7 , Q6 / Q7 that are bolted to the chassis. They all had the thermal grease / plastic insulator / plastic stepped iso washer on them EXCEPT U6 ----U6 had no iso washer or plastic insulator.
Looking at the scem , is that correct as far as the way its wired? These transistors all have the metal back , not plastic. MAX_112 PowerAmp_2012.pdf
