JCM800 pots change failed
  • JCM800 pots change failed
    Hi, I changed all the pots in my amp and now the volume is really really low. I respected all the same pots resistances but I changed some of the log 1meg pots for linear pots. Any ideas where could I check first to find the problem?? What can I test??
    Thanks,
    JCM800 is a series, not a model. What is the model # of your amp?
    If it was working properly before, than you most likely made an error in your wiring, or installed a new defective part.
      Just found the error, wrong wiring, thanks for the answer.
        Was it really necessary to replace all pots?
        It typically suffices to disassemble the pots and clean the track and all metal contacts with Deoxit on a Q-Tip.
          It typically suffices to disassemble the pots and clean the track and all metall contacts with Deoxit on a Q-Tip.
          Agreed. Were all the pots bad? I've owned four Marshalls from that era and as I recall the pots were of decent quality. I think I still have a couple of those pots leftover after a modification I did to one of those amps. They're perfectly good, so I kept them.
          Restoring the originals would have preserved the original tapers too. Looking at the pots in there now I don't imagine they're of better quality than the originals.
