I would like to ask for some advice about the annoying noise that occurs when I use distorted pedals on a vox ac30 cc2, mostly to understand if it is a problem with the pedals or the amplifier.
This noise (which sounds more like the same note played twice than a noise) is not particularly loud in volume, but it is still very annoying to me as a player.
In some articles found online I read that it could depend on coupling caps but I would like to have some advice from those who understand them more than me.
This amp has been off for almost 10 years and in the last year I have replaced the rectifier valve, power tubes and filter capacitors, as well as a general cleaning of all contacts.
In case you advise me to replace the coupling caps, I would like to ask you, since here in Italy I cannot find the Mallories, if the Vishays can be a valid alternative.
Thanks so much.
Thanks so much.
