I just received another Hiwatt HLR "Little Rig" amp head in for service and after opening it up, having to deal with possible damage to the Standby Switch from the chassis mtg screw positioned directly below it, correcting the cattywampus orientation of the Pwr & SB switches to correct orientation, I powered this amp up, and.....having heard RF buzz from the previous three amps, one being another HLR model, I again heard that RF buzz out of the speaker, and saw it clearly visible on the output at idle.
After seeing the sketch of the Primary wiring diagram of it's power xfmr, I see it, and their other two models I've been inside on are all a tapped autoformer primary, rather than a split primary. for 120V mains, both primaries are in parallel (properly phased, of course).
I got to wondering if there's any relationship to this 120V Mains applied to the lower half of an autoformer-style primary rather than having two identical primaries in parallel, with regards to the clipped heater waveform that is providing that abrupt step that is the RF source that gets coupled thru the input preamp tube? I've attached a schematic of their Custom 50W Amp schematic, which is also an Autoformer style primary (uses a rotary switch to select AC Mains taps). Their Little Rig is hard-wired per the correct voltage tap, but still same configuration. With the Autoformer primary, you're running twice the primary current thru that lower half than if there were two primaries in parallel for 120VAC Mains.
For some reason, the client (Hiwatt) doesn't want this problem fixed.
