Remove silver insert in knobs?
They should just be glued in. So boiling water as mentioned, or hair dryer etc. should warm enough to soften the glue. You will still probably need a pin or something to pick it out.
With the example in the picture, I think you could also punch it out from the back.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
It is already broken, so I would take side cutters or something and chip away the sides of the volcano to expose the edge of the insert. Then you could get under it with an Xacto blade or a jeweler's screwdriver or whatever tool you like.
I'd be afraid to punch through from the back, I might collapse the shallow cone shape.Education is what you're left with after you have forgotten what you have learned.
- Likes 1
Originally posted by Enzo View PostIt is already broken, so I would take side cutters or something and chip away the sides of the volcano to expose the edge of the insert. Then you could get under it with an Xacto blade or a jeweler's screwdriver or whatever tool you like.
I'd be afraid to punch through from the back, I might collapse the shallow cone shape."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
