I have a new build of the Weber stand alone reverb. With a pedal board feeding the input there is breakup/clipping when reverb is brought up with the Mix control. it seems to be accentuated with the Tone control in the treble region. I don't notice it with my Strat plugged straight in, but it does appear with a Les Paul & humbuckers plugged into it.
Voltages are all on the high side - PS point A-353VDC, point B-289VDC, heaters at 6.7VAC. They were higher with the PT wired to 120VAC, so I am using the 125VAC winding instead. No documentation on the point A expected voltage and the layout indicates that point B should be 250VDC.
The kit came with a JJ 6V6S tube, which I think can handle the point A voltage, but I think PS resistor R16 needs to be increased to lower the point B voltage to the 12AT7 and 12AX7 to 250VDC.
I don't see any forum posts elsewhere related to voltage problems with this kit. So I wonder...
Am I on the right track?
Weber 5G15 Schematic.pdf
