Hey all,
I have a Traynor TS-25 that is highly susceptible to some type of noise (RF, EMI, something else?). I am very familiar with the Traynor TS series and have not had one behave like this before. I actually have a TS-25B and TS-50 here at the same time, and neither of them have this issue. I've worked on and owned TS-25's before and they didn't behave like this.
With nothing plugged in, the amp is quiet. When you plug in a guitar and turn the volume to zero, it's quiet.
However with a guitar plugged in and the volume up there is a loud buzz.
The noise is quieter when chassis is in the cabinet with steel panelling on the top and sides, but still present.
I have tried adding a small cap from input ground to chassis, no change.
The noise is only present on HIGH input. LOW input is ok.
All components on high input going into the TL071 test ok on the meter (2 diodes, C1, C3, R1, and R2).
All ground connections test good on the meter.
Amp sounds good, just the buzz.
There is a noisey 25kHz waveform present, scope shot attached (20us/div, .2V/div).
What else can I try? Looking forward to hearing your thoughts.
