Hi! First time posting on one of these things. I’m having issues with my Deluxe Reverb Reissue and I was hoping someone could help me with figuring it out. Thanks in advance for anyone offering advice.
I have some crackling when playing through it on both channels regardless of volume the amp is set at. The harder I strum the more it crackles. There is also a present hum/buz now. Turning the reverb knob up increases the hum/buz by quite a bit. None of the other knobs affect the noise. This amp has the Fritz mod btw, Which brings reverb over to the normal channel.
I’ve tried swapping out all the 12ax7 tubes one by one with a known good one from my 5e3 amp. This did not change anything.
I swapped out the 6V6’s and GZ34 tubes from my Princeton Reverb Mojotone clone. This did not change anything either.
I pulled V3 12at7 and this did not fix the issue. I then put that tube in place of the 12at7 in V6 and that did not solve the issue either.
So I feel like tubes are likely not the issue.
I tried unplugging the reverb tank and that did not fix the issue either.
I opened the amp to look at the board and noticed that the black heater wire on V5 had broke and it was hanging onto the tube socket by a thread. So I stripped that back and soldered it back. This did not fix the issue.
Another thing I noticed as on the V6 tube socket was that there was a strand of wire coming from pin 7 and it was touching pin 8. I was curious if it was soldered there and it wasn’t. I was able to push it away with the lead on my multimeter. This did not fix the issue either.
I’ve tried 3 different speakers and 3 different power sources, including a power source that is filtered through my Furman PST-8 power conditioner. None of these fixed anything.
Again, thank you to anyone who takes the time to give me advice or suggestions on what to check next.
