One of my steady clients sent over two of their Matchless DC30 Combo Amps. I think that's all they have in their inventory. I checked our inventory, and see we have four....one that I've never serviced. What I have noticed with this beautifully built amp...is they all have significant HUM when you turn either channel all the way up. There's more gain in Ch 2, which has the EF86 Pentode preamp tube. One of the two had squeal on the Pentode channel, which I was able to cure by swapping out that tube with one that has a shield within a 1" tall tight circular rubber compression ring on the body of the tube. I also had on one of the two amps that came in, substantial hum on V2 tube that follows the volume control for Ch 1, as well as the Driver tube. Both are now as tame as I could get them.
I've noticed all of these DC30 amps appear to have the same high degree of hum. Not that one needs the volume pots turned all the way up to encounter that, but....it still bothers me. I've never made a project out of this, nor has any client requested their DC30 to be cured of it.
This morning, after swapping V1 & V2 preamp tubes with each other, which did yield better residual noise/hum than before, I connected the output of the amp to my HP 3580A Spectrum Analyzer and collected these two plots of the residual hum/noise...one with the Volume controls at full CCW, the other with that trace plus Ch 1's Volume at full CW setting for comparison.
I've thought about connecting my HP 712C Power Supply up to this amp, to see what the residual noise looks like without it's healthy-looking Power Xfmr turned on and powering the circuits.
Anyone out there find similar behavior with their Matchless DC30 amps?
