My GA-5 fried the power tranny a few weeks ago in a sort of dramtic event (the amp went BZZTTT and smoke started coming out from the PT). I replaced it with MM clone and replaced all the electrolytic capacitors as well. When I turned the amp on again it now worked but there is a "crackle/buzz" that appears with the note. It is more prominent with the lower strings, but it can be heard in the upper registers as well if you listen closely (particulary if you bend or sustain the note). It sounds very much like a blown speaker.
So far I've tried:
*checked the speaker cone - no damage
* different set of tubes
*replaced a blown plate resistor and it still crackles (most of the other resisitors are within 10-15% of spec).
*replaced the coupling cap that is attached to the volume pot - no dice.
*resoldered the filter cap and PT connections and anything that looked funny
*tried wiggling the tubes to see if I could loose socket
The only possible clue - I did the chopstick test and none of the connections made noise except around the input jacks - the two resistors connected to the input jack made noise (but they tested fine at 45k), and the volume pot connection to the preamp tube made noise when struck with the chopstick. The volume knob itself is noisy even though I cleaned it with contact cleaner. Not sure if any of this is related to the crackle though.
Any ideas would be appreciated - I'm stumped!!!
Rick
So far I've tried:
Rick
