Originally posted by Indyryder02
View Post
E.g.:
- With V3 removed V2B is not heated, so will be dead.
- Lifting any components after V2B ( e.g. C111) cannot change the hum on V2B pin 1.
- Lifting R113 disconnects V2B from the power supply.
But as this makes the noise go away, even though the triode doesn't work anyway, the noise must be coming through R113 i.e. from the B+ on C101.
Check if you can see the hum on TP4.
