Marshall JCM800 2203KK Hum issue
  • Marshall JCM800 2203KK Hum issue
    Hello everyone, i'm looking for help!
    i have a JCM800 KK in for repair, everything looks fine and triple checked almost everything but cannot figure it out what generates hum in the preamp section.
    I removed all the preamp tubes one by one, and it goes away once i remove the V2, but stay there if i remove V1 (slight reduction)
    I found this video on YouTube, same noise, but i can record something to post if needed (the hum is at 0:30 sec):
    https://www.youtube.com/watch?v=sT7N...sorGrahamLeach
    Resoldered all the parts on V1 and V2 section, the "the Beast" circuit" and the Eq/Gain/Master pcb without success (no bad solder joint at this point)
    Tried several other preamp tubes, didn't cure
    The amp is almost new, have been used sometimes in a couple of years, tubes seems pretty new too
    Any suggestion would be very appreciated!
    Ct
    How about a schematic?
      Of course, here you have it
        I get errors trying to open either of those files.
          Should be fixed now
            Opens for me.
              Yes, they open for me now, too.
              What DC voltages do you have on the 15V rails? Also measure ACV on those rails to make sure they are clean.
                Ok, going to measure those today and post them
                  ok, so the voltages are:
                  9.47 Vac on WP117 and WP118
                  9.48 Vac on WP118 and WP119
                  and after the regulators:
                  +14.90 Vdc on + of C126
                  -15.04 Vdc on - of C135
                  All seems pretty stable, they arrive correctly on the othet side of the CON4 ribbon cable
                    What voltages do you have on HT1, HT2 and HT3 ?
                      Ht1 367.7 v ht2 237.6 v
                      ht3 229.5 v
                        Those seem kind of low. What DC volts do you measure on each side of R127 in the main supply cap. area? (also check AC volts there)
                          R127 has 438.8 V and 431.5 V. WP109-WP112: 341.1 VAC
                          WP105-WP106: 98 VAC
                            Any clues?
                              What is AC volts on each side of R127 ?
