My JC-77 functions but due to "operator error" fell on its face sometime in the last 10 years. The switch for the chorus protrudes a bit proud of the cabinet and, along with gravity, fate used the switch as a lever to crack the PCB in the corner. It was at that point that the chorus feature stopped working. I had thought that the board was just bent but after opening it up, I see that 7 of the traces no longer have continuity. Also, the 2 pots for rate and depth on the chorus are physically broken and need replacement. I'm pretty sure I know what needs doing, but I thought I'd post if anyone has better suggestions.
I plan to:
- reinforce the top side (no traces side) of the board with 2 plastic ribs glued with gorilla glue to stabilize the cracks
- find a resource online for best practice for repairing traces. I can solder competently but never broke traces before. My inspection found 7 broken traces. Photo below.
- source and install replacements for the 2 broken pots. I need to check the vendor list.
- bench test and reassemble
I plan to:
