Hi all,
Hoping for a little advice here on where to start with this Peavey Deuce VT amp I am working on. For some reason, the 2nd channel (Effects) has barely any output at all. You can still hear the guitar signal and effects working, but barely any output. The first channel (Normal) appears to be working fine and sounds fantastic! Full output, and functionality.
I have tried using both the Mixer feature with the pedal and plugging directly into the 2nd channel inputs and have the same results.
All power tubes tested strong. Any advice would be appreciated!
Thanks,
Brian
Thanks,
Brian
