I suggested a 1 meg pot, not resistor. Wire the wiper to the grid resistors. That way you can dial down th intensity . As you found out, just raising that resistor does nothing. If the trem signal is too hot, it can run your grids into the bias voltage. I mean the bias level acts like a wall the thing hits.
Have you scoped this? How hot is the trem output? And what is the cathode bias on the tubes?
