Hum.....
I disconnected the dual 40 uF can and clipped in new filter caps. I replaced the third 10uF filter cap. Still have a 120 hz hum with or without all tubes inserted. How does noise get to the speaker with no output tubes?
Also getting a large current draw which trips the circuit breaker inside the amp.
Original PH204 diodes in the rectifier seem to be working properly, could they cause noise? Hum starts with very low V on the variac and gets louder quickly as the variac is slowly dialed up. I am able to test using the variac and keeping the current draw low.
What else can cause 120 hz hum?
Much thanks in advance! MarkO
![Click image for larger version Name: IMG_20220413_153538436.jpg Views: 0 Size: 1.36 MB ID: 958103](filedata/fetch?id=958103&d=1649882432&type=medium)
