I think Jon Snell meant to lift (one end of) C10 in order to isolate the preamp from the power amp.
Instead of physically disconnecting C10 you can disconnect the treble pot wiper instead.
If still hum with C10 disconnected, it's definitely not coming from the preamp, i.e. before the PI.
Disconnected wire from center lug of treble pot and no change in hum. No controls have any effect on hum with nothing installed @inputs except for presence control.
If you have other 12ax7's available that are known good tubes please try several in the V2 position and see if any of them makes a difference.
Installed four(4) new(and known good) JJ 12AX7s in V1-V4, no change in hum. Noticing a high pitched squeal on channel 2 on anything above 5 on volume and presence controls. Channel one now is aheavily distorted signal. Only tube that is not new, known good tube is GZ34 rectifier tube.
Post 19 Jon Snell asked me to check coupling at NFB loop. Looking for that location on schematic
The Negative Feedback Loop consists of a 27k feed from the output transformer, we'll call it R nfb A, the potential divider we'll call it R nfb B and the 0.1uF shaping capacitor to reduce the frequency of nfb response. ( Make it sound brighter ).
If the feed between the 27k resistor and the 5k pot is next to a heater/mains lead, that can produce hum.
As a matter of interest,
many that change output transformers or do major rework to this type of amplifier forget to check the polarity of the speaker phasing.
If it is upside down (180° out of phase) or the anode feed to the transformer have been crossed by mistake, the nfb becomes Positive Feedback, and we have all heard the scream or droning noise from microphones or instruments too close to the loudspeakers.
Sometimes, depending on the characteristics of the transformer, it can produce a lower frequency tone.
