Originally posted by Helmholtz
View Post
Marshall 1962 Bluesbreaker (JTM 45) Reissue Hum
Originally posted by ca7922303 View Post
Yeah, is there away to remove a wire off of tremelo intensity pot to check that cap? Otherwise I'll have to start desoldering wires to get to the bottom of the board. Wires are very tight on it.
You should be able to disconnect the wire right at the pot, unless these pots are mounted on the circuit board?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostYou should be able to disconnect the wire right at the pot, unless these pots are mounted on the circuit board?1 Photo
Also, C3 is reading(OL.) in circuit?
v1 1-3(183vdc) red probe on pin 1, black on pin3
6-8(193vdc) red probe on pin 6, black on pin 8
v2 1-3(190vdc)
6-8(128vdc)
v3 1-3(181vdc)
6-8(176vdc)
V4 1-3(165vdc)
6-8(201vdc)
If I'm looking at this right, C2 is the 0.22u cap and it's not there.
Originally posted by g1 View PostNo you are not looking at it right. Are you using the schematic from post #7 ? Where do you see C2 on it? I see a .22uF cap connected to the intensity pot with an * symbol beside it. According to the notes that means it is mounted 'off the board'. So I expect it to be mounted right at the pot lug.
Originally posted by g1 View PostNo you are not looking at it right. Are you using the schematic from post #7 ? Where do you see C2 on it? I see a .22uF cap connected to the intensity pot with an * symbol beside it. According to the notes that means it is mounted 'off the board'. So I expect it to be mounted right at the pot lug.1 Photo
I have some pots in hand I'd like to try the humdinger wiring to see if it will reduce the hum. Can you tell me what values would also work while I'm waiting on the 100 ohm 5 watt Pot? Thanks
You can roughly calculate the required pot wattage from 50 divided by resistance.Last edited by Helmholtz; 04-29-2022, 03:44 PM.- Own Opinions Only -
See the link in post 71. Merlin uses a 500R/80mW pot. You shouldn't go higher than 500R. The lower the resistance the higher the wattage.
