Sony Tc-366
  • Sony Tc-366
    I picked up a Sony Reel to Reel it seems to play ok but have noticed the Left VU meter is pegging out the right one bounces around to the music but does not peg out.
    Never ever having played with one I'm not sure if I have a problem or not Any suggestions?
    Thanks
    Jason
    Do you mean it stays pegged all the time, or it is just showing hotter signal than the other side?
    If it's just showing hotter level, turn the tape around and see if it stays with the meter.
      Yes it is a hotter signal. Not to sound ignorant but by turning it around just putting the reel on the left side on the right side switching them?
      nosaj
        For clarity, do both meters sit at '0' when the tape isn't running and there is no signal applied?
          Yes both at zero with no signal.
          nosaj
            I'm not completely familiar with that machine, but on some you can monitor the inputs independently of heads. If that's the case, see if it does the same thing with an identical signal into both L&R inputs. That would help you decide if it's a meter circuit problem, or a tape/head/ etc. problem.
              nosaj
              Yes. So that the actual sound would be heard backwards. But L side is now at R head, so if one side was recorded hotter, it should now show hotter on the other meter.
              edit: I'm assuming this is a 2 track machine.
                Clean the record/playback contacts. A very common issue with all tape and cassette recorders.
                  ok I cleaned all 3 heads and it reduced it quite a bit its not hitting the red section now. Still about a unit off from the R VU meter.
                  I flipped the tape around and the left meter is still higher than the Right side.
                  I did notice on rewinding or FF I had to hand bump the wheel to get it going. So i'm thinking may need to lube the motor?
                  Thanks guys
                  nosaj
                    It's more likely an idler tire, belt, or other rubber. The first thing would be to either clean, rejuvenate, or replace any rubber parts. They are usually the first to go on any deck.
                      There will be calibration trimmers for the meters, playback levels etc.. But first you want to make sure the signal path is all good through the various switches like Jon mentioned.
                        Whats the consensus on using denatured alcohol on rubber parts.
                        nosaj
                          Denatured? I use isopropyl to just wipe them clean, but it doesn't rejuvenate. The volatile hydrocarbons do that.
