Originally posted by The Dude
View Post
Ampeg GS-15R Gemini VI
Originally posted by mtlbasslad View Post
No idea - it's supposed to be a Fender pot from Solo guitars...Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 1
Originally posted by mtlbasslad View Posti think the so-called 'matched tubes' are not at all.
Tube idle current measure is beyond my current knowledge...
You measure the resistance of the OT primary halves, then with unit running you measure voltage at same OT primary halves. Write down the 4 numbers then divide the voltage by the resistance for each half. So for example, you might measure 3VDC across one half that had measured 145 ohms. 3/145 equals .0206, or about 21mA current.
For your ampeg, if the OT wire colors match the schematic, it makes it easier. The primary CT wire is red, and blue and brown go to the power tube plates (pin3).
The red wire (A), comes off the rectifier diodes.
So you would measure resistance of red to blue, and red to brown. Then with amp running measure volts at same places. Then do the calculations for each half.
If it were an amp that used 4 power tubes, you would further divide those numbers by 2, as each OT primary half would be running 2 tubes.
- Likes 1
Originally posted by g1 View PostOT voltage/resistance method is non-invasive, just a couple measurements and some math (volts divided by ohms).
OT primarys measured from junction of rec diodes to Pin 3 are both 133.5 ohms.
Voltage 2.1 & 5.0 - the 5.0 on the tube that still wants to redplate a bit. This calculates to .16ma & .37ma I believe... now what?I'm not old - I'm vintage
Tubes do what they do based upon the relationships between elements.
So did you first try to adjust balance control for minimal hum? And if the plate voltages are even, are the screen voltages the same? With no screen resistors they should be, but... And more important, the control grid voltages. Are they both the same?Education is what you're left with after you have forgotten what you have learned.
- Likes 1
Originally posted by Enzo View PostTubes do what they do based upon the relationships between elements.
So did you first try to adjust balance control for minimal hum? And if the plate voltages are even, are the screen voltages the same? With no screen resistors they should be, but... And more important, the control grid voltages. Are they both the same?I'm not old - I'm vintage
So why not change that?
15 years could have been used to read some books and learn the basics.I'm not old - I'm vintage
For the Fender amps that have the 'output matching' pot, the instructions are just to adjust the pot for minimum hum, by ear.
I think if you did that, then checked again the idle currents for the power tubes, they would be fairly close to balanced. (or close to zero differential DC volts from plate to plate, like Helmoltz said)Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 2
