Hiwatt DR201 200W amp...biasing without cathode resistors
  • Hiwatt DR201 200W amp...biasing without cathode resistors
    This past week I finally got to see one of the Hiwatt DR201 200W Bass Amps. Came over from Lon Cohen's facility nearby, with No Output. Tubes? was the suggested hint, along with a pair of J/J KT88 used boxes, one marked 35mA, other as 36mA. I got the iphone camera out to begin by photographing the unit for my database. Same proportions as the Custom 100W and 50W heads, but larger and much heavier.
ID:	960068 Click image for larger version
ID:	960070 Click image for larger version
    When I tipped it up to remove the rear panel and then the chassis mtg screws, I found one of the chassis screws missing, with the other one of the front screws ready to fall out. No Lock Washers.
    I removed the chassis carefully, and moved it over to my test bench, then spotted the shredded adhesive-backed aluminum ground foil on the floor of the cabinet. Looking at the chassis on my bench, I saw the probable cause of the HT Fuse having blown. Nearest O/T side KT88 was frosty white.
Name:	Cabinet Foil-4.jpg
ID:	960074 Click image for larger version
ID:	960076 Click image for larger version
Name:	Pwr Tubes-1.jpg
    Inside views of the chassis. I noticed this one didn't have the 1 ohm Cathode Resistors, which Hiwatt is finally beginning to install in their amps. Also noticed no ballast or bleeder resistors across the parallel'd 100uF/500V PS Buss Caps. I stopped to see what I could download from the internet on the schematics for this amp. Various renditions out there from over the years of production.
ID:	960080 Click image for larger version
ID:	960082 Click image for larger version
    I made a list of the items I had found, sent that off to Hiwatt for getting their approval to proceed ahead, as I had just received an email from them asking if this had the 1 ohm cathode resistors installed. I had received a string of their 1 ohm 1W 1% Carbon Film resistors for adding those to their amps. And had their 220k 1W CF resistors for installing on the buss caps to make this safe to work on, as without them, it can take many hours to drain off. Got the approval to proceed ahead. One feature I did like in their wiring was the pair of bias adj pots for each half of the output stage.
    Before I made that move, after having looked at the wiring, not yet realizing the upper Buss cap (220uF/400V was on the opposite side of the chassis from the three dual-100uF/500V buss Caps, all having a common ground buss on the neg terminal. They couldn't be running the power tubes off of less than 500V, surely? Nope. That single 400V 220uF buss cap was the top of the stack, and found from it's positive terminal, the BRN and YEL wire soldered to the middle pair of power tube sockets Pin 3 were 9.86 ohms and 7.96 ohms difference from that cap terminal. I checked the where that RED wire went, seeing a RED wire at the S/B switch. That DCR difference from the buss cap to there was insignificant to the plate taps from the C/T.
    I removed that bad KT88, along with the other three tubes, one of which no longer had it's alignment peg (broken off/gone). My bias probes/meter aren't rated for over 600V, so I began by using the measured DCV reading between the 220uF/400V buss cap to the two plate terminals where the O/T primary leads attached, then divided that value with the DCR value to get the plate current and wrote that down. Did that for the five power tubes, finding the three remaining tubes from the chassis did work, and had assumed the two from the client also worked. I ended up with what I could make up for two pairs. Difference in their discrete plate current was 17% on one side, 7% on the other. Plugged them in and adjusted the bias for 50mA total on each side, targeting for 25mA/tube, though didn't know just how well that really was. I didn't check the screen currents in the process.
    After revising the cathode wiring from being grounded to chassis at each tube socket, adding the 1 ohm resistors standing up Japanese style, and adding the 220k bleeder resistors across the buss caps, I was finally able to check the cathode current thru each tube. One side was way off, running nearly 50mA per tube while the other was not quite 25mA per tube. After landing them at 24mA & 26mA on each pair, I was quite pleased, as well as somewhat befuddled with the method of using the primary plate wires' DCR and voltage drop from C/T to calculate/set the bias. Far easier with having those cathode resistors to measure across. Or, at lower voltages, using bias probes that have the cathode sense resistor inside the probe body.
    Thanks for the story. IME the current Hiwatt company pretty much uses the old designs, warts and all, with the exception of some modern "hi gain" models. I'm glad to hear they're finally adding cathode resistors, although I don't know why they would skip the 220k bleeders (included in the originals) on a 700v amp. .
      Great write up... how does it sound ?
        Oversight, apparently. I didn't have the time to find the date code on when this amp was built, though that might be in the S/N on the rear....20012020. Didn't look that old.
        Hiwatt was going to send me the correct aluminum grounding plate for the cabinet, as they have stopped using that horrible adhesive-backed foil, which just gets ripped to shreds after a few removals.
        Here's the photos of the update to the chassis, having added the 1 ohm 2W Metal Film Cathode Resistors, along with the 220k 1W ballast/bleeder resistors on the buss caps.
ID:	960210 Click image for larger version
ID:	960212 Click image for larger version
ID:	960216 Click image for larger version
        While cleaning up the power tube sockets, the one between the IEC 320 Mains connector and fuses....the lead of the 1k 7W screen resistor broke, then while putting that back into place, it broke off from the end cap! I had misplaced my string of 1k 5W MO resistors, but managed to scrape away the coating of the end cap and remaining stubble of the lead wire, with just enough of that lead to form a tight-fitting lead wire, soldered it into place and salvaged that resistor. That can be seen if that image is enlarged. Amp had to go out that day, so I was kinda loosing it for lack of a common part that was on hand. Still haven't found the remaining 5W resistors (here someplace!).
          How does it sound? Awesome!! Seems to have more balls than an Ampeg SVT 300W amp. Power and output xfmrs are very impressive, as well as heavy. I only got to hear it thru the shop speaker (Ampeg SVT115HL4 15" bass cab). There's another DR201 coming down to me from San Francisco, so I'll hopefully have it over at the Guitar Dept / rental depot so I can plug this into some cabinets and shake the building.
          They also make a 400W amp, which no doubt is even more impressive. As long as roadies are carrying it. This DR201 needs handles on the two ends to make it manageable, IMHO.
            Amen to that
              As if by magic. Built in 1979 in England using the largest transformers ever. More iron for bottom end grunt, than any Fender or Ampeg.
              Click image for larger version  Name:	screenshot 2020-04-29 at 15.00.56squashed.jpg Views:	0 Size:	67.2 KB ID:	960255 Click image for larger version  Name:	screenshot 2021-05-16 at 08.34.21-1squashed.jpg Views:	0 Size:	119.2 KB ID:	960256 Click image for larger version  Name:	screenshot 2021-05-16 at 08.35.05squashed.jpg Views:	0 Size:	211.4 KB ID:	960257
              Repaired by myself in 2021. New sextet of KT88s were fitted, the first time from new I was told.
              Being gigged regularly and the roadie must suffer from severe back ache. They weigh a ton and are really well built. Drop it off a 4 X 12 cab and it will destroy the stage.
              Pity someone wrote on the chassis the valve types. Spoils the aesthetics as far as I am concerned.
                Hs ha.. looks nothing special on the photo until you scale up the transformer against the pre amp valves. Must weight an absolute ton.
                  That's some massive iron on those!
                    AMEN to that!! Awesome looking amp!
                      I've spent the past several days trying to create the Preamp Turret Board wiring diagram (underneath side of the DR201, and haven't had any assistance from the one tech up in Toronto. I know they must have the layout of both that Preamp Turret Board as well as the Power Tube Turret Board. All I got from him was EL34 World's website and looking at what they had in prior Hiwatt amp schematics. I did download a couple others that I didn't have, that offered some clues while staring at the Preamp Turret Board. I finally figured it out, apart from NOT yet knowing WHERE the Feedback resistor/cap attach to. That 8.2k/100pF network resides on the Power Tube Turret Board, and there are just three wires that come over from that board to the Preamp Board....the two Grid Drive busses and the Feedback return. Neither of the Hiwatt DR201 schematics nor similar 200W output stage schematics I have offered the clue, so I've left that connection off of the otherwise completed Schematic, along with the DC voltages.
                      I drew it up in National Instruments Multisim 11.0, and copied the D-size schematic into Word, Landscape, then printed it via Adobe Distiller so I have a PDF file of it.
                      Hiwatt DR201 200W Bass Amp Schematic-1.pdf
ID:	961626 Click image for larger version
ID:	961628 Click image for larger version
                      I used the three-phone jack input circuit that has a LINKED input that feeds both the Normal and Brilliant Channel that they've recently been using in place of the dual-sensitivity 2-jack inputs per channel. I haven't yet created a symbol for the Neutrik NL4 output jack that's on this amp. Otherwise, I think I've figured out their preamp wirng scheme and transposed that into the schematic I've posted.
                      Now....just WHERE does that feedback network connect to??
                        As usual the NFB should be fed to the right side grid of the LTPI, i.e. the inverting input.
                        Means it should be connected to the node between R25 and R26, C12 being the coupling cap.
                        Biasing the PI grids via the DCCF is rather strange.
                        The bias feed resistors R30 through R33 should connect after the coupling caps and not to the PI plates.
                          OPPS! That was late in the day when I was moving R30-R33 & C13-16 around. I'll correct that today, along with connecting the Feedback network. I also left out a power supply coupling resistor that's at the end of the Turret Board....1k 7W sourced from the Screen Supply....and left out it's filter cap in the process.
                          This 'exercise' was in preparation to wiring up the chassis and turret boards of my KT88 power tube test fixture, based on the DR201.
                          Thanks for taking a close look at this!
                            The common end of R38-41 needs to be grounded.
                            There's no DC path from the power tube grids to the bias supply.
                            There shouldn't be a DC path between the PI plates and bias supply.
                              From what Helmholtz and Dave H found, and the additional details that I had left out from yesterday's session, I've made the corrections and updates. Created a symbol for the Neutrik NL-4 connector, after first ringing out a connector to see where physically in the concentric circles of the connector 1+ 1-, 2+ and 2- actually reside. Outside ring is 1-/2-, and inside ring is 1+/2+. I fumbled with the graphics until I cobbled that into the drawing. Then, created the dashed line to represent the static shields of the Power and Output xfmrs so it didn't look like I was grounding the core. It no doubt is from the physical mounting anyhow.
                              I also did a fresh pair of Preamp Turret Board images without the erasures that were on one, that all looked like white wire placements.
                              Hiwatt DR201 Bass Amp Schematic-2.pdf
ID:	961658 Click image for larger version
ID:	961660 Click image for larger version
                              One of the details I didn't document when the amp was here, was the cap values across the two sides of the Standby Switch, as seen in this last photo. Those voltage values are no doubt 630V, and guessing from the size, at least 100nF. I didn't place any cap symbol across the Standby Switch in the schematic yet.
