Hello,
I've recently acquired a Carvin TS100 power amp. I'd purchased new power tubes for it and when I went to bias them, I get a very low current measurement of 10mA across both tubes on channel 1. This measurement happens when the bias pot is fully clockwise. The new tubes are JJ E34L. The tubes that came with it are Groove Tube GT6L6-R. After I reinstalled the GT's, the bias current is higher, but still quite low at 20mA. All current measurements are taken from the transformer center tap, per the amps instructions.
I've attached the manual and schematic. Can someone here lead me in the right direction to get the amp biased correctly, or repaired?
Thanks!
Thanks!
