Output is normal until engaging graphic eq button, then no output and hum. Active/Peak light stays on at power on, standby off or on and EQ button off or on.
Ampeg SVT-ii Pro No output w/EQ on
Look at your overall circuit. The whole amp is tube circuits, and they are working for you. The graphic section however is solid state using op amps, and they have their own low voltage power supplies. Also, the LEDs also run on those low voltage supplies.
SO if it were mine, I'd first check the low voltage supplies, both +15v and -15v. One supply could be missing, or may have lost filter cap and so is real hummy.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostLook at your overall circuit. The whole amp is tube circuits, and they are working for you. The graphic section however is solid state using op amps, and they have their own low voltage power supplies. Also, the LEDs also run on those low voltage supplies.
Originally posted by ca7922303 View Post
Hum only increases with the master volume. Gain and volume do not increase hum. EQ was fine until I installed a new shuangang 6550B. Other 5 are GE 6550A's. Coincidence or otherwise?
SO if it were mine, I'd first check the low voltage supplies, both +15v and -15v. One supply could be missing, or may have lost filter cap and so is real hummy.1 Photo
Are you using the 2 Pro schematic? See attached. I don't see R44/R45. I see R60/R61 on pg.4Attached Files"Everything is better with a tube. I have a customer with an all-tube pacemaker. His heartbeat is steady, reassuring and dependable, not like a modern heartbeat. And if it goes wrong he can fix it himself. You can't do that with SMD." - Mick Bailey
The power supply is not on the EQ board. Go to the power supply itself, as g1 also suggested. Find where the 15v supplies actually comes from. Offhand in your chart I do not see -15v. It could be as simple as a failed 15v zener, but you have to look in the power supply.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostThe power supply is not on the EQ board. Go to the power supply itself, as g1 also suggested. Find where the 15v supplies actually comes from. Offhand in your chart I do not see -15v. It could be as simple as a failed 15v zener, but you have to look in the power supply.
Here is the layout, does this look like your main board? R60/61 are near the top just left of center near the 5=pin connector that says "to preamp".Attached FilesEducation is what you're left with after you have forgotten what you have learned.
