Hi,
Recently I acquired an old JC-120 (1978 serial number). Everything is working fine in the amp, but I have some strange behavior on channel 2 when Vibrato or Chorus Effects are selected.
I attached a little vídeo of the problem and the schematic for the version of the amp, basically you can feel the effect in the speaker until the signal gets to certain volume threshold then it kind of cuts/interrupts (actually I think it is shutting off because I don't see any signal on that speaker). Measuring the voltage at the speaker output if the signal is above 200mA there is no problem at all, but once it goes down to a lower value the problem happens.
The only modification I can see in my amp is the MN3002 IC that was replaced at some point for a MN3007.
I didn't find anything related to this sort of problem on the other threads on the forum, so I decided to start a new one.
I'm trying to clarify the whole schematic since I have never worked on a solid state amplifier before. I can't see clearly how the switching for the effects is done.
Any pointers on where to start to check would be appreciated.
Thanks.
Thanks.
