PT for Peavey Backstage
  • PT for Peavey Backstage
    Surprised at how difficult it has been to track down a replacement PT for a Backstage II amp. Number is 705-17950. I don't really want to go to a lot of trouble retrofitting something to this little chassis on an amp I can buy used for $100.
    Anyone better at this than I am?
    Did you try Peavey?
    What taps do you need?
    nosaj
      Which Backstage is it from ... 30, 50, 110 ?
      Tryhttps://www.tubeampdoctor.com/en/parts-for-amplifiers/transformers/mains-transformers/
        The amp is over 40 years old, PV will not have the part.
          All I know is it is a Backstage II solid state. I have tried emailing Peavey, they don't respond. I called once, they did not answer. Their parts program and service staff is not what it once was in my experience.
          I already looked at TAD, he doesn't have it.
          I'm guessing this is a lost cause.
            Randall, I have two that might work for you. LMK if you need more measurements or voltages:
Name:	IMG_1841 Large.jpg
            http://amps.monkeymatic.com
              Thank you very much xtian. The call has been made to cease and desist on this amp. Not really worth any more time.
                Xtian's transformers
                705-18712 it is about a 30-0-30 transformer, which rectifies and filters to about 40vDC rails. It is used in the Bandit, the Backstage Plus, the Basic 40/50/60models, the Studio Pro 40/50 models
                705-18711 I am no6t sure what that was used in. Should be similar era I note it is smaller so used in less powerful models.
                  If anyone would know that Enzo, it would be you.
                    Rockin' Johnny can use it as an extension cab now the amp's been condemned.
                      I have been trying to figure out how to post a new topic on this site and have failed. I have a Peavey Backstage amp and need a new overdrive switch can anyone help?
                        as John asked above; which Backstage is it from ... 30, 50, 110 ? If its the little OD pushbutton this switch is available Click image for larger version
                          Go to this link and look above the sticky topics for a blue button that says '+ New Topic' and click on that button: https://music-electronics-forum.com/...hooting-repair
