Good Afternoon. I have a Ultra 112 that apparently was hit by 220. After replacing fuses and bringing her up with a variac.... everything looked good except for the channel switching. I know that the crunch channel does not operate without the fs, and here is where it goes downhill!!
The fs is a 3 button with red ultra led, yellow lead led on the first button, middle button has a green bypass, and last button is a red effects led. I cant get the crunch to operate...The lead yellow led is operating the ultra channel, and when switched to ultra red, i get very little distortion, but still controlled by the ultra channel. I have all the j-fets/mac xstr. and replaced them to no avail. I did notice that the connector pins on the breakaway board (501-503) were soldered together..unlike what the schematic diagram showed....so i reversed that. When i emailed peavey...The parts department said that was the wrong fs and it needs rewired....However, when i called to verify it....They said it was the correct fs. If anyone can give me some advise or direction while i clear my head...That would be GREATLY appreciated.
Thank you for your time
Art
Art
