I'm working on a Fender Prosonic, doing a cap job. I was advised by a tech on another forum that I could take the original 4.7 uF filter up to around 20uF if I wished. I wonder what the effect of this is on the tone of the amp? I used the 20 uF, and it seems like the amp is a little "harsher", maybe? I'm curious what taking it down to 10 uF would do? What kind of effect on tone? Thanks in advance!
Effect of screen node filter on tone
The value of the screen filter cap affects time constant and amount of screen compression.
A lower value should result in a somewhat softer attack.
Why did you change the original cap?
https://www.thetubestore.com/lib/the...-Schematic.pdf- Own Opinions Only -
- Likes 1
I have one of these in for a check-up now as well (bad 100uF/100V cathode bias cap on the bias board on mine). I also noticed the small cap in the doghouse and wondered if it was a typo on the schematic as the board looks like it can easily fit the 47uF (stencil almost appears as if was expecting a much larger sized cap).
The cap is in the screen node of the filter section, right after the choke.
The schematic is ubiquitous and can be found easily.
I replaced the original 4.7 uF because I was doing a cap job - original e-caps, late 1990's.
I swapped to a 20 uF at the suggestion of a tech on another forum. The 4.7 uF 500V is nearly impossible to find in a quality brand.
I am really mostly interested in what effect the different value has on the overall tone and character of the amp.
Thanks!
Originally posted by Fred G. View PostI am really mostly interested in what effect the different value has on the overall tone and character of the amp.
BTW, it's good practice that the OP provides the schematic - saves all others time and guesswork.
The amp is likely going to be a bit "spongier" and less chunky/tight sounding. If that's not something you like, you can experiment with higher cap values."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
