I have a 1986 Marshall Artist 4203 combo with a dead OT. It is a drake 292-700/6. I think the /6 is a date code. Not coming up with anything. The amp runs 2 EL34s at 4/8 ohms. Anyone know what sub I could use?
help subbing a Marshal OT
It is a standard 40/50W EL34 transformer, nothing special.
Have you looked here; https://www.tubesandmore.com/product...ement-marshall
If a lie down type, look up DSL401 https://www.tubeampdoctor.com/en/out...for-40w-dsl401 or standup type JCM800 series https://www.tubeampdoctor.com/en/out...8-16-ohm?c=105
Hope that helps.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
- Likes 2
That is an 8k OT for KT66s.
EL34s want around 3.4k."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View Post
So it could be run at half impedance (using the 8/16 taps as 4/8 taps) making it 4k.
Reason is that compared with designated 8k operation the primary peak current will be almost doubled, which might exceed the OT's current limit at full power.
Second reason is, that an 8k OT typically has around twice the DCR of a 3.4k OT of same size, due to more turns of thinner wire.
This means doubled power loss.
So output will be lower by 5W to 10W and OT wire temperature will increase.Last edited by Helmholtz; 06-25-2022, 07:53 PM.- Own Opinions Only -
- Likes 2
I was reluctant to suggest that solution.
So output will be lower by 5W to 10W and OT wire temperature will increase."Take two placebos, works twice as well." Enzo
