A new hum issue (they just keep happening). I am not sure of the model of this amp, closest I could find was a model 6161 but the schematic is slightly different.
When I first brought this amp to operating AC level it seemed to work fine. It had a 2 prong cord and I thought I would update to a 3 prong, well that is when hum started.
At first it was 60 Hz. I disconnected the mains ground from the chassis and that made no difference.
I had since updated all filter caps (22 uF, 10 uF, 10 uF), updated the 6973 output tube pair cathode cap to a 47 uF. I have all these caps and the mains ground going to the same ground connection.
Now the hum seems to be 180 hz to 240 hz, jumps from one to the other. If I touch the volume knob it seems to change sound. This is very odd; if I touch the two screws on the left side of the amp top, the hum changes sound, these screws hold the chassis in place and are currently hanging out of the cabinet, not connected to anything. If I move my hand near the chassis, hum sound changes.
The 3 input jacks are not shorting jacks.
The upper part of pin 8 of the rectifier broke off while soldering (must have been fatigued from something) so for now I jumped pin 8 to pin 1 and moved connections to pin 1.
The hum volume changes with the volume pot. Hum is present with no instrument connect. The hum is present with a guitar connected and present when playing.
The tremolo works but is turned off.
The model 6161 schematic shows two channels, I do not have that. My V2 has one half of the tube unused.
Scope readings taken at the speaker connections.
Thank you in advance for any guidance. MarkO
![Click image for larger version Name: IMG_20220705_160551658.jpg Views: 0 Size: 539.2 KB ID: 963722](filedata/fetch?id=963722&d=1657053334&type=medium)
![Click image for larger version Name: IMG_20220703_160255643.jpg Views: 0 Size: 1.11 MB ID: 963718](filedata/fetch?id=963718&d=1657053338&type=medium)
