Lovely amp designed by Soldano, looks better than it sounds.
Anyway, clean channel is bleeding into the Overdrive channel:
With clean preamp up, Unit switched to OD channel, clean master turned down and OD master turned up.
turn down Clean preamp pot, bleed goes away.
Amp uses Vactrol 5C1 opto-couplers for switching
When I ground the signal at V2b pin 7 the bleed stops, but I still have OD signal- that shouldn't be according to the schematic.
Opto #51 looks like it's supposed to ground the OD signal.
Unless I was confused, it was getting late.
