Hi everybody, got Randall RG75 G3 combo for repair, when turned ON it hums for about 5 seconds, then pops and from there on everything goes normal. Only happens when it was OFF for longer time, like few minutes. If turned OFF and ON within minute or so it starts normaly. First thing coming to my mind is some cap, or Relay? Anybody had similar problem? Any ideas?
Randall RG75 G3 Combo, hum then pop, then everything OK
Originally posted by glebert View PostThere is a relay that cuts the signal to the speaker outs that is supposed to have a delayed turn-on. Do you hear the relay click to on, and does it happen immediately with power-on?
What power amp module do you have (including date code or anything else that might be a a clue)? In my experience with Randalls like that they mixed and matched preamp and power amp modules, and have had ones where the "right" schematic wasn't available but I could piece it together from two others that were similar.
Originally posted by glebert View PostWhat power amp module do you have (including date code or anything else that might be a a clue)? In my experience with Randalls like that they mixed and matched preamp and power amp modules, and have had ones where the "right" schematic wasn't available but I could piece it together from two others that were similar.
Does this one match?Attached FilesOriginally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Since you mentioned a hum and pop, I would look to see if there was DC coming out on the speaker outputs for that first few seconds. You could measure this with a DMM or even just look if the speaker is being pushed and held (in or out). If it is not DC then I would try to figure out if were 60 or 120Hz that comes from the AC line.
- Likes 1
Originally posted by glebert View PostSince you mentioned a hum and pop, I would look to see if there was DC coming out on the speaker outputs for that first few seconds. You could measure this with a DMM or even just look if the speaker is being pushed and held (in or out). If it is not DC then I would try to figure out if were 60 or 120Hz that comes from the AC line.Last edited by Emetal; 07-16-2022, 11:09 PM.
Originally posted by Emetal View Post
Exactly as you sad, speaker is PUSHED and HELD for few seconds. There is 25 VDC on the speaker while it hums. So what now, where the DC is coming from in those first few seconds? (I am sorry for asking everything I don't do repairs every day, just sometimes)
- Likes 1
I believe there is a turn on delay circuit around C13 and D14 area.
Like glebert said, do not connect the speakers til the amp is repaired. Check if DC volts at Q3 collector change during turn on til a few seconds after.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 1
DC volts on Q3 between ground and collector DID change, went up for few seconds and then down, i checked it once, and when I wanted to check it again R15 and R16 smoked out and turned black...
Originally posted by Emetal View PostR15 and R16 smoked out and turned black...
Maybe you will get lucky and that string will have been what was causing the issue. Suggest replacing Q7,8,9 as well as those burnt resistors and D5. Check R17 as well.
Power up with no speakers or load, preferably on a lamp limiter. Check if the output still goes DC at turn on.
- Likes 1
