I have an Ampeg R12R reissue from the 90's and it's having issues with the line out jack. I never use the line in or out jacks but had heard that they can be problematic due to moisture. Started hearing a very loud squealing sound a couple of nights ago. When I placed a jack (patch cord) in the input jack after using some contact cleaner the squealing went away, at least for a day or two - then it returned. If I push a cable into the jack with force, pressing down, I can induce the squealing....What would be a permanent fix to this issue? I'm not a tech but can follow directions for simple stuff. Can I leave a patch cable connecting the in and out line jacks to prevent the issue, at least temporarily; will doing this affect the tone? Should I go to an amp tech or is there something I can do?
Repairing Line out jack on Ampeg R12R Reverb Rocket Reissue
Replace the sockets is the correct answer however, if you use a patch lead until you can take it in for repair, there will be no difference in the tone.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
- Likes 1
Originally posted by Jon Snell View PostReplace the sockets is the correct answer however, if you use a patch lead until you can take it in for repair, there will be no difference in the tone.
In my limited years of working on valve amplifiers from 1959 to current day, I have never seen a Reverberocket with line in/out jacks. Is this an addition I wonder.
Even the 1996 drawings of the re issue version does not have an effects loop and back in 1961 we didn't have effects loops at all. Just the cry baby and fuzz box. (Life was simple then!)
Yes replacing the sockets is the same procedure as replacing the jacks.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
I see Line out and Line in jacks on the schematic, an FX loop if I ever saw one.Attached FilesEducation is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostI see Line out and Line in jacks on the schematic, an FX loop if I ever saw one.
The last Rocket I had in for repair was a 1961 5Y3 model with 2 x 6SL7, 2 x 7591a and a 5Y3. Nice Jensen 12" speaker.
Lovely overtones and not very common here.
The UK doesn't see many newer types of Rockets.
Yep if that is ctone's model, it does have a switched jack. Careful cleaning of the switched contacts will fix that issue as it will with most hardly ever used switch jacks.
A mushroom headed TRS jack plug with the T & R connected together as a link with the S left open will get you out of trouble for now.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
Thanks Enzo, I missed that one, (it has new fangled silicon stuff in it!)
It would help a great deal to know what the model number is. Type and valve lineup would also help because that clearly isn't Enzo's schematic nor my schematics as I haven't got a schematic with line in/out in them
That jack socket is a Cliff type.
I have made a photo of a gold plated socket but the idea is the same.
Insert a cleaning strip, (I use https://uk.rs-online.com/web/p/elect...eaners/1015564 ), where the arrow is pointing. The contact gets tarnished over time and causes lack of volume/distortion etc.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
Originally posted by Jon Snell View PostIt would help a great deal to know what the model number is. Type and valve lineup would also help because that clearly isn't Enzo's schematic nor my schematics as I haven't got a schematic with line in/out in them
I use a burnisher, but if you cut a 1/8 inch strip off the end of a business card, use it as a cleaner. Poke a plug into the jack to open the contacts pointed out in Jon's photo. Slide the card strip between the contacts. Now remove the plug so the contacts pinch down on the strip. A gentle back and forth with the strip will polish the contacts.Education is what you're left with after you have forgotten what you have learned.
I was able to use a very thin file to clean the contacts and used contact cleaner. The screeching stopped but now unless I have a patch cable going from the line in to the line out of the effects loop the volume controls on the amp lose about 80% of their volume.......with cable plugged in, everything is fine. The amp tech I use is out of town for a couple of weeks......any suggestions in the meantime....I guess I could just leave the cable in till he gets back.
Originally posted by ctone View PostI was able to use a very thin file to clean the contacts and used contact cleaner. The screeching stopped but now unless I have a patch cable going from the line in to the line out of the effects loop the volume controls on the amp lose about 80% of their volume.......with cable plugged in, everything is fine. The amp tech I use is out of town for a couple of weeks......any suggestions in the meantime....I guess I could just leave the cable in till he gets back.
That is why we use a card strip, soaked in switch cleaner.
Replace the socket and the job is done or go back to plan B and fit a link plug.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
