Hello, I'm back!
This time I have a problem with Orange Rockerverb 50 Mk2. It has some annoying high frequency fizz on high volume, at the edge of breakup of single channel, where PA starts to distort. Both channels affected.Long story short I was able to track it down to reverb driver stage:
- if I pull out driver tube, fizz is gone;
- if I plug out reverb tank, fizz is gone;
- if I pull out the reverb recovery stage, fizz is present;
- if I plug out only the tank output, fizz is present.
So it looks like this oscillation is going to EL34 screen grids through the HT node. According to the unofficial schematic from the Tube-Town forum, the reverb transformer uses the screen supply without the additional filtering.I measured R21, R22, R23, R66 and C12 without desoldering, looks ok (R21 is more like 186K). Also I've tried to scope the oscillation, it appears right after the R23 and goes to the grids of both driver stages. Can it be bad R23 or the problem is more complex?
Schematic contains few errors, I didn't trace them all, but R22 is 2K2, reverb driver and recovery stages are 12AT7, lead channel gain is 1M and so on.
I attached an audio sample, with and without a reverb tank.
reverb_tank_distortion.mp3
Orange_RockerverbMKII_PS.pdf
Orange_RockerverbMKII_Pre.pdf
Orange_RockerverbMKII_PWR.pdf
