Qsc Dca 3422 Amp shot dead
  • Qsc Dca 3422 Amp shot dead
ID:	965349 My qsc dca 3422 was plugged into two Ev 12 boxes. after a rumble of sound, it stopped dead. all leds are off.
    Can use the rear data port to diagnose the problem?
    Is there any fuse ?
    Please help
    Probably the internal fuse has blown unfortunately as the power supply is a switch mode device, it is likely to be short circuit and require specialist repair. Click image for larger version
Name:	Screenshot 2022-07-25 at 13.45.53.png
      Thank you John
      so it’s not just a simple fuse. That would’ve saved it
      • Exclusive PowerLight power supply for great bass
      From QSC website
        You will have to investigate, I can only guess as I cannot fault find it.
          You never know, it may be just a blown fuse
            schematics attached
