Phil Jones Bass Briefcase - schematic question
  • Phil Jones Bass Briefcase - schematic question
    There are SG1, SIG, BST, SG-IN connections, but I'm not sure that I've linked it right. Help needed.
    The copy of the schematic is so poor quality, I cannot read the Chinese sybols to connect then up.
    If your copy is legible, join the sybols and that is how it is wired.
      Original schematic in PDF also attached. Better quality connected sheets schematic attached in first post in zip file, because resolution limit.
        I read 3 labels as:
        SIG
        SG1
        SG-IN
          Originally posted by g1 View Post
          I read 3 labels as:
          SIG
          SG1
          SG-IN
          Thanks, also BST. Is that mean EQ in parallel?
            I see BST and CUT as boost and cut. Not sure where they are going.
              My mistake connect SG-IN and OUT, thanks for help.
