Magnatone weirdness
  • Magnatone weirdness
    Working on a early 50s ? Varsity 197. Its been re-capped and im seeing that all the resistors are in spec except 1. Right after the 6sj7 theres a 500k on the scem. I will attach a pic . Out of the amp it tests 234k and has red/yel bands (220k ? ) . So , the amp sounds ok but gets farty/ flubby when you crank it up. I thought i would replace this resistor...put in a 470k. This completely kills the signal. Double checked everything . Any ideas? This part looked like it was factory. ??
    magnatone_M-197-3-V_PM.pdf
    I would, without even testing anything, replace the 10M on pin 4 of the 6SJ7. High value older resistors are notorious for going even higher in value.
    A 6SJ7 won't be happy with 500k anode load. 220k is much nearer the mark. Re fit the 220k. 234k is well within spec of a 10% tollerance.
    Check the voltages look about righ around the 6SJ7 and 6V6.
      Looks like red/black/yellow to my eye. SO 200k. The amp worked with the 200k, I agree, put it back in, or really use a new 220k.
      I am OK with the 10meg for grid leak bias, even if it goes higher, it still should allow the grid to collect a voltage.
      Check the plate and screen voltages on the 6SJ7.
      On an amp of this age I expect the three electrolytics to be worn out. And the four "film" caps are likely paper caps and are almost assuredly leaky. I'd worry about those caps way before I worry that a resistor is off spec.
        The schematic calling for 500k is what caught my eye ...maybe a different version of the amp? The model numbers match
          Beware "model numbers match". I have one Gibson model that has THREE different published schematics, plus from examples through my shop I have THREE hand drawn schematics that are all different and different from the published ones. SIX different schematics for one model name.
          I suggest schematics should be considered approximations. And remember these are just guitar amps, not precision equipment.
            DC voltages from both ends of the plate resistor will show if the stage is working properly and which resistor value results in best biasing.
              I was looking through very similar pre 1953 Magnatone schematics and some use 47k , some use 100k at the inputs of the amps. Mine has 47k 's
              http://magnatoneamps.com/schematics.html
                I don't think that is an 'official' schematic. I would think if someone was doing a clean up on the original schematic, they mis-read the 200 as 500.
                  Im not sure what voltages i need here. Here are some measurements ---
                  6sj7 plate is 82vdc , and 230v on the other end of the 220k i just installed
                  the 6V6 has 260v at plate
                  B+ out of the rect is 310v
                  bias calculates to 39ma for the 6v6
                  all the caps are new , all the resistors are new except the 1k/7w , 250/5w and 10k/2w , which test ok
                    Skylark by chance?
                    nosaj
                      I'd monitor B+ (preferably on a scope) and see if it's sagging substantially when the amp is driven hard.
                        Means 148V drop across the plate resistor, corresponding to a plate current of 0.7mA.
                        No wonder you get no decent signal with a 470k resistor as that will drop most of the supply voltage, leaving no useful plate voltage.
                        82V plate voltage is rather low/unfavorable. A lower resistor value (dropping maybe 100V) would increase headroom.
                          Seems to me it was GA17 or GA19, if failing memory serves me...
                            Is that plate or cathode current? What is the 6V6 cathode voltage?
                            You could lower the cathode resistor to 220R, aiming for a cathode current of 50mA.
                            Does that include the cathode bypass cap?
                            Best measure output power.
                            Should be around 4W.
                              Heres something...check out how this 6sj7 is wired compared to the Varsity scem. Should i try this? Mine is close but pin 5 is going straight to ground
                              http://magnatoneamps.com/schematics/dickerson_1946.pdf
