Hickok 605A
  • Hickok 605A
    Please upload a manual.
Name:	Screenshot 2022-08-08 at 07.19.26.png
      Fuse light?
      Which pilot light do you mean?
        Meter is not moving. Found out light only comes on if there is a problem.
          12AX7 does light up
            Is the meter open circuit? Put your meter across it in on Ohms and the movement should move.
              If the meter movement is OK check the resistance bridge.
Name:	Screenshot 2022-08-08 at 19.27.24.png
                Manual with wiring diagram at BAMA: https://bama.edebris.com/download/hi...kok%20605a.pdf
