I have not one, but two Peavey Deuce amps in the shop at the same time. The one in question is a later VT series. I repaired a bad solder connection in the mormal preamp section, and replaced the broken automix input jack. It allows the normal and FX channels to either be switched or run in parralel.
Questions are thus: I have never played through one of these before. It's basically a solid state preamp into a four 6L6 output into 2x12s. The normal channel seems pretty dirty to me, is it supposed to be?
And, it has two what I believe to be original 8 ohm speakers wired in parralel, but the main output jack is labelled 8 ohm, and the aux is 4 ohm. What gives? It sounds better to me plugged into the 4 ohm jack What was Peavey up to here?
